I am building a utility which will give me the list of child part numbers as an output for a given part number and I want to expose this utility using Rest API so that the users can execute this utility themselves.
I have followed the below steps to get the utility in Swagger UI but I am not able to see the added entry.
i) Added the below entry in rest.properties.xconf
<Property name="ext.webservices.rest.test.resources" multivalued="," default="ext.webservices.rest.test.TestUtility"/>
ii) Written a java file. PFA.
Please let me know if there is any other step I need to follow to achieve the expected result.
Thanks in advance.
Hari R
