Hi All,
I have a document of called Test so when my part is attached to this particular document I want the attribute value of document should pass to WTPart..
Following are the attributesname :
How I can achive this from alias attribute.
@HelesicPetr , @manoj_dokku2 , @BjoernRueegg
@Ajit_Kulkarni Yes we can do it I am able to achive using the below mapping .
describes@wt.part.WTPartDescribeLink~describedBy^com.demo.Test2~com.demo.itemGroup
Here, com.demo.Test2 is the Internal name of document and Itemgroup is the attribute Internal name
@Pushpak_Old I did not reply on this post. I am not sure about Alias attribute. Should be possible on Global attributes.
