How can I get the "SOFPART" attribute value of the document type object in the promotion?
smcvr
SOFPART contains multiple string values
I wrote a code to deal with this situation, but the attribute value is empty. Where am I making a mistake?
CODE:
try {
    wt.maturity.PromotionNotice pn = (wt.maturity.PromotionNotice) primaryBusinessObject;
    wt.fc.QueryResult qr = wt.maturity.MaturityHelper.service.getBaselineItems(pn);
    while (qr.hasMoreElements()) {
        java.lang.Object obj=(java.lang.Object)qr.nextElement();
        if (obj instanceof wt.doc.WTDocument) {
              wt.doc.WTDocument wtdoc = (wt.doc.WTDocument) obj;
            wt.content.ContentHolder contentHolder = wt.content.ContentHelper.service.getContents(wtdoc);
            wt.content.ContentItem item = wt.content.ContentHelper.getPrimary((wt.content.FormatContentHolder) contentHolder);
              com.ptc.core.lwc.server.PersistableAdapter persistableAdapter = new com.ptc.core.lwc.server.PersistableAdapter(wtdoc, null, java.util.Locale.getDefault(), new com.ptc.core.meta.common.UpdateOperationIdentifier());
                persistableAdapter.load("SOFPART");
                SOFPART = (java.lang.String) persistableAdapter.get("SOFPART");
} catch (Exception wte) {
    wte.printStackTrace();
Hi @joe_morton
In his case there is a issue with the retyping the result object.
SOFPART = (java.lang.String) obj2.get("SOFPART");
 If the attribute contains multi values the return object is an array with a string not a String so this is the case why his final variable is empty.
PetrH
19 REPLIES 19
avillanueva
22-Sapphire I
(To:smcvr)
Is "SOFTPART" an IBA on the WTDocument? Or are you trying to get the name a soft typed sub-type of WTDocument? If its an IBA, I can post code for that. Might already be posted. Also looks like you are interrogating the primary content of the WTDocument. Why? Attributes should not be part of the content file.
smcvr
(To:avillanueva)
Hi @avillanueva,
"SOFTPART" is an IBA in WTDocument
avillanueva
22-Sapphire I
(To:smcvr)
smcvr
(To:avillanueva)
Hi @avillanueva ,
I tried to get the "SOFPART" value defined in the document added to the promotion with iba, but it did not work.
I don't understand where I'm making a mistake, can you give me an idea?
CODE:
try {
            java.util.Locale locale = wt.session.SessionHelper.getLocale();
               com.ptc.core.lwc.server.LWCNormalizedObject obj2 = new com.ptc.core.lwc.server.LWCNormalizedObject(wtdoc, null, locale, new com.ptc.core.meta.common.UpdateOperationIdentifier());
               obj2.load("SOFPART","Arac_Kodu");
                Arac_Kodu = (java.lang.String) obj2.get("Arac_Kodu");
HelesicPetr
(To:smcvr)
Hi @smcvr
What windchill version do you use?
I would use new API PersistableAdapter
https://www.ptc.com/en/support/article/CS138252?source=search
PetrH
smcvr
(To:HelesicPetr)
Hi @HelesicPetr ,
Thank you.
I changed the code but still the values are empty
try {
              com.ptc.core.lwc.server.PersistableAdapter obj2 = new com.ptc.core.lwc.server.PersistableAdapter(wtdoc, null, wt.session.SessionHelper.getLocale(), new com.ptc.core.meta.common.DisplayOperationIdentifier());
HelesicPetr
(To:smcvr)
Hi @smcvr
Do your SOFTPART IBA definition is exactly "SOFTPART "?
I don't believe that the function does not support a multi value attributes.
Perhaps not. If not you could use the another method that I have mentioned in the provided link by @avillanueva .
PetrH
smcvr
(To:HelesicPetr)
Hi @HelesicPetr ,
SOFTPART is multiple values but Vehicle_Code is a single value and both are empty
smcvr
(To:smcvr)
By the way, when I want to get the value of the part type object with this code, it gets it, but not the attribute value of the document type object.
HelesicPetr
(To:smcvr)
Hi @smcvr
try to use null to all other inputs
com.ptc.core.lwc.server.PersistableAdapter obj2 = new com.ptc.core.lwc.server.PersistableAdapter(wtdoc,null,null,null);
PetrH
smcvr
(To:HelesicPetr)
Hi @HelesicPetr ,
Unfortunately, it didn't happen.
HelesicPetr
(To:smcvr)
Hi @smcvr
Does exist the parameter on the WTDocument type? And what is the internal definition of the attribute?
PetrH
HelesicPetr
(To:smcvr)
HI @smcvr
I don't know what you have done wrong but in my case it works.
The multivalue attribute returns an array of a string
PS> your catch (Exception wte)  can case that the parameters are empty because you don't know about the error that you can not cast the Array to a string 😄
PetrH
joe_morton
(To:smcvr)
To me, this code looks like it should work. Here's some debugging tips:
  • it doesn't look like you're using contentHolder or item - maybe try removing those
  • when you do obj2.load - make sure you are using the internal names of the attributes exactly. I believe these are case-sensitive
  • is the SOFPART attribute added to WTDocument, or to a subtype? If it's on a subtype, you may need to add logic to ensure you are only dealing with WTDocuments of that subtype. I've used code that does something like this:
String subtype = doc.getDisplayType().getLocalizedMessage(java.util.Locale.US);
		if (subtype.equals("XXXX")){
  • Additionally, you can always debug further by printing lines out to the methodserver logs. Ex: System.out.println("debug message");
Hope that's helpful!
Hi @joe_morton
PetrH
smcvr
(To:HelesicPetr)
Hi @HelesicPetr
When I took the attribute value as an array, the code worked.
Thank you for your ideas 🙂
HelesicPetr
(To:smcvr)
Hi @smcvr
I have an advice for you.
If your code does not work, always open a Windchill log method server and check the errors.
The error with the retyping had to be there because you use a try with catch (Exception wte)
PetrH
Thanks, I should refactor that API and update my code.
d_graham
(To:smcvr)
Why not clearly state the problem when you initially post?
Your post is a bit ambiguous.
