Version: Windchill 11.2
Use Case: In the Create New Document Wizard, the values in Combobox2 should dynamically change based on the selection in Combobox1.
Description:
Hi there,
I want to implement a dynamic selection for an Azure-Windchill integration project.
I’ve written and tested two different functions, both of which are working:
There is no issue with the functions; both work successfully when I manually input a repository name.
When the user starts the Wizard by selecting “New Document,” there are two different comboboxes in the opened window.
I can dynamically retrieve the values for Combobox1 with a data utility as soon as the window opens, and this works without any issues.
However,
My question is: How can I populate Combobox2 with the desired values based on the selected value in Combobox1? (Both of the comboboxes must be dynamic)
P.S. I don't have any problems with the Azure-Windchill connection, i can get correct values by my functions.
I solved the problem by these steps;
1- Created DataUtility for Combobox1 for get Repo Names from Azure, added Js action
comboBox.addJsAction("onchange","TestScript()");
2- Then edited CreateWizStep
3- Created Servlet for parse folder names.
Hi @Anil_SAD,
Thank you for your question.
Vivek N
Community Moderation Team
