How can I populate Combobox2 based on the selected value in Combobox1?
Version: Windchill 11.2
Use Case: In the Create New Document Wizard, the values in Combobox2 should dynamically change based on the selection in Combobox1.
Description:
Hi there,
I want to implement a dynamic selection for an Azure-Windchill integration project.
I’ve written and tested two different functions, both of which are working:
- Function - func1: Retrieve repository names from Azure.
- Function - func2: Take a repository name as a parameter and retrieve folder names from the first two levels within that repository.
There is no issue with the functions; both work successfully when I manually input a repository name.
When the user starts the Wizard by selecting “New Document,” there are two different comboboxes in the opened window.
- Combobox1 holds a list of repository addresses.
- Combobox2 should hold the folder names within the repository based on the "selected" repository attribute value in Combobox1.
I can dynamically retrieve the values for Combobox1 with a data utility as soon as the window opens, and this works without any issues.
However,
My question is: How can I populate Combobox2 with the desired values based on the selected value in Combobox1? (Both of the comboboxes must be dynamic)
P.S. I don't have any problems with the Azure-Windchill connection, i can get correct values by my functions.
