Version: Windchill 12.1
Use Case: Ensure that all WTDocuments associated with a given WTPart have secondary content. If any documents lack secondary content, display a warning popup to the user. If the user proceeds, allow downloading of available secondary content as a ZIP file.
Description:
In Windchill, WTDocuments can have secondary content such as PDFs or additional attachments. However, not all documents necessarily contain secondary content. When a user selects a WTPart, the associated WTDocuments should be checked for missing secondary content before proceeding with further actions, such as downloading the documents.
Hi @YS_10608297
Thank you for your question.
Best regards,
Hi @YS_10608297
You should describe your use case. What does the user do ? Select WTPart? and what next?
What does the select mean? to put the wtpart to a structure? or you have some utility to download a content from the WTDocumnet based on WTPart selection?
Or do you describe a creating connection between the WTPart and WTDocumnet?
I do not understand your situation and what you really want.
You should describe what the system has to do more descriptive that others can understand your thoughts .
PetrH
Agree with @HelesicPetr. Title of post and write do not align. It reads like a copy/paste of requirement of something you are being asked to develop. It lacks context.
