Hi Community,
I have loaded windchill demo data using loader command and now I need to understand whether we have mBOM in Windchill server or not.
How we can differentiate between different BOM structures available in the Windchill Server from the UI?
I went through some PTC articles and also youtube video where I found that we can have option of Electrical or Mechanical before starting Part Name, number etc. How I can enable that?
Attaching ss for reference.
Sid
It is huge area what you are asking.
The different type of WPTart is set during creation.
Open a wtpart new wizard and you can see different type of wtpart if it is configured
Also if the wtoart is autogenerated during CAD Document check in you can set the specific type of WTPart on the CAD Document type by type and attribute management.
If you want to create different BOM as a mBOM you need to use Transformer BOM tool
if you want to see difference you can use compare structure function
all should be part of a studying lecture.
PetrH
PetrH
Hi two simple replies:
