I'd like to export automatically pdf and dwg files wihle publishing it on windchill.. For the moment I managed the pdf files export using "Presentation Export" tool. But not the dwg ones.
In addition the dwg file in zipped folder as shown
is there any way to manage these tow problems ?
THANK YOU
Yes, it is possible to automatically “export”/download any file generated by publishing.
I’ve written a few utilities to do this.
But without a description of your use case, 🤷♂️
Hi @NL_9194215
You can use VWS After loader
Here is article where the save locally or to a network is described.
https://www.ptc.com/en/support/article/CS348848
PetrH
