How to open Info Engine when Windchill is not starting?
lchavarria
11-Garnet
Hello guys, I really hope all you are doing great.
Do you know how to open Info Engine when Windchill is not starting? I was setting a connection with Active Directory and  when I finish all the normal configuration I restart the server to verify my work as the process requiere but Windchill never restart again, so I check my data and later I realize that the JNDI connector was wrong.
So how can I change the JNDI connector if you access it using the Info Engine who is access using Windchill who is nos starting.
Thats why the name of this discussion: How to open Info Engine when Windchill is not starting?
2 REPLIES 2
Cliff
(To:lchavarria)
You could modify in WindchillDS directly. If needs, can have a case to get help.
Cliff
@Cliff Thanks for your advice.
I was trying to configure Active Directory and some info was wrong for this reason when I tried to start Windchill it could not open.
I fix it editing the files that have info about the AD connector manually, doing so, Windchill start again and I was possible to set the connector correctly.
@Cliff Thanks again for your help
