Hello, please tell me how to save changes to the file web.xml (Windchill_home/codebase/WEB_INF/web.xml)?
Here is a resource which explains the structure of a web.xml file. Hope it will help.
Not sure in which context the question is, but generally the file can be modified in any text editor.
If the question is about how to save file from code > The are file handling packages available with programming languages which can be used for that purpose.
May be a more elaborated use-case description will help better understand the ask.
