How to save changes to the  file web.xml
VladiSlav
Hello, please tell me how to save changes to the file web.xml (Windchill_home/codebase/WEB_INF/web.xml)?
4 REPLIES 4
Not sure in which context the question is, but generally the file can be modified in any text editor.
If the question is about how to save file from code > The are file handling packages available with programming languages which can be used for that purpose.
May be a more elaborated use-case description will help better understand the ask.
Arpit-Singhthere are examples of working with the web.xml or information, how does it work in Windchill? I only know in General terms how to work with the web.xml, but this knowledge is not enough for me to understand the full picture
Arpit-Singhthank you very much for the useful and accessible information
