How to search all children within a Part structure?
khimani_mohiki
Version: Windchill 12.1
Use Case: In the top level Part structure of a car or truck, search for children at all levels with an matching attribute value, ie show all parts within the car made from Aluminium
Description:
I need to search attributes of all children at all levels within a Part structure. I want to report on attributes like state and materials for all Parts within a car structure, this may be 6 levels deep.
Currently the method being used is to export to excel and use pivot tables.
I have previously used a JSP with some java code I wrote to recursively search for children at all levels with a certain state, this works but is limited to a single attribute input, I want to select any usage or item attribute as input and see a filtered list of child parts matching the criteria.
Any ideas on what approach to take?
4 REPLIES 4
One possible approach might be to write a java method that recursively returns all child objects for a given WTPart. Then you could use that java method in a query builder report
So return all children at all levels into a WTCollection, then use that in the query builder?
Actually, now I'm doubting myself. I think java method can only return strings in query builder. 😓 It's been awhile since I've worked with them.
Adjust your approach by entering the attribute names separated by a delimiter in the same field you are entering the attribute name now.
From there you should be able to adjust your code to search for these attributes. 😁
