How to set the conflict description message for implementing rename using custom listener
Vishwa_RADDI
Version: Windchill 12.1
Use Case: I have written custom listener will use the event "IdentityServiceEvent.PRE_CHANGE_IDENTITY" for if WTPart New Number is NOT 10-digit validation and not able to dispay the conflict description message in Event Console
Description:
10 REPLIES 10
@Vishwa_RADDI ,
I saw your post and it seemed very doable.
I renumbered a WTPart to be 6 characters long.
As expected, I get a failure and the error description is exactly what I coded.
Seems to work to your spec, unless I'm misunderstand your post.
David
windchill.developer@yahoo.com
Hi David,
how do you set this custom message on Conflict event console? I have tried using WTException(new WTMessage); and just throwing an exception its not working. let me know how do we set?
Vishvanatha
Hi @Vishwa_RADDI
It is more complicated then just throw WTException.
You should create object a ConflictException with a ConflictElement that contains a ResolutionType and a ConflictType with your message to a user.
I did similar exception for deleting WTPart that is linked to a process plan. User has a option to repeat and finish deletion or nothing else.
PetrH
Hi Pert,
Thanks for suggestion, could you please add snipet of source code so I will try.
Vishvanath
Hi @Vishwa_RADDI
Knowledge base contains some information
CS104731 - API to override conflict on EPMWorkspaceHelper
PetrH
Hi PetrH,
Yes I have already tried with this examples as  you mentioned, still not printing any ERROR.
Vishvanatha
Yes, because the example just shows one part of the solution.
You have to throw the correct error
ConflictException conflict = new ConflictException(new ConflictElement[]{conflictElement});
throw conflict;
PetrH
Yes I have tried as below snippet code, still not working
ConflictElement[] conflictElements = new ConflictElement[setConflictElements.size()];
conflictElements = setConflictElements.toArray(conflictElements);
throw new ConflictException(conflictElements);
So it works
You just do not see any message that the user could read 😄
So you have to write the message to the user.
PetrH
we dont have any user level settings in this API's it should work or could you provide snipnet so I will check?
