Import missing preference
DKWc
Hi All,
I'm trying to import a missing preference at Site level.
followed article CS152142 it throws an below error:
org.xml.sax.SAXParseException; lineNumber: 1; columnNumber: 23; Document root element "csvPreferenceInstance", must match DOCTYPE root "null"
Referred to one of the article on community and used the below xml
<?xml version="1.0" encoding="UTF-8" ?>
<!DOCTYPE PreferenceImpExp SYSTEM "standardX20.dtd">
<PreferenceImpExp>
<PreferenceInstance>
<name>Part to Document Association Logic</name>
<clientName>WINDCHILL</clientName>
<value>Yes</value>
<locked>false</locked>
</PreferenceInstance>
</PreferenceImpExp>
this also throws below error
Cannot import "Preference Instance" "Part to Document Association Logic" as there in no matching preference definition with name "Part to Document Association Logic".
any help would be appriciated.
Fadel
23-Emerald I
(To:DKWc)
load below file and restart your server :
Fede
Fadel
23-Emerald I
(To:DKWc)
What preference is missing and what version are you running
Fede
DKWc
(To:Fadel)
The below highlighted preference is missing.
windchill version using is 12.1.2.4
Fadel
23-Emerald I
(To:DKWc)
Fede
DKWc
(To:Fadel)
Thanks a lot it worked
