Hi All,
I'm trying to import a missing preference at Site level.
followed article CS152142 it throws an below error:
org.xml.sax.SAXParseException; lineNumber: 1; columnNumber: 23; Document root element "csvPreferenceInstance", must match DOCTYPE root "null"
Referred to one of the article on community and used the below xml
<?xml version="1.0" encoding="UTF-8" ?>
<!DOCTYPE PreferenceImpExp SYSTEM "standardX20.dtd">
<PreferenceImpExp>
<PreferenceInstance>
<name>Part to Document Association Logic</name>
<clientName>WINDCHILL</clientName>
<value>Yes</value>
<locked>false</locked>
</PreferenceInstance>
</PreferenceImpExp>
this also throws below error
Cannot import "Preference Instance" "Part to Document Association Logic" as there in no matching preference definition with name "Part to Document Association Logic".
any help would be appriciated.
What preference is missing and what version are you running
The below highlighted preference is missing.
windchill version using is 12.1.2.4
load below file and restart your server :
Thanks a lot it worked
