Version: Windchill 12.1
Use Case: I would like to list all items of a selected folder, then to extract all documents related to the selected item
Description:
I've found several solutions using Odata, but I don't succeed to rerpoduce the same requests. And I would prefer to use REST queries to get result formated in json. Does the REST API can give access to all data that are accessible from the user web interface ?
Thanks for any help.
Fred
Context: Although the product version is 12.1.2.0, the REST Services version is 2.3.
I get the content of folder with the OData request :
https://<url>/Windchill/servlet/odata/v5/DataAdmin/Containers('OR:wt.pdmlink.PDMLinkProduct:681234555')/Folders('OR:wt.folder.Cabinet:681234597')/Folders('OR:wt.folder.SubFolder:681267970')/Folders('OR:wt.folder.SubFolder:681267975')/FolderContentsand because of the error message : "The returned query result has exceeded the query limit, and only 50,000 result returned." I try to limit the number of results by using the 'top' filter :
https://<url>/Windchill/servlet/odata/v5/DataAdmin/Containers('OR:wt.pdmlink.PDMLinkProduct:681234555')/Folders('OR:wt.folder.Cabinet:681234597')/Folders('OR:wt.folder.SubFolder:681267970')/Folders('OR:wt.folder.SubFolder:681267975')/FolderContents?$top=10but it doesn't work, the result is the same.
Does anyone knows if it is an issue due to the old version of the rest api that I use ?
Thanks for any help
Fred
Hi @FM_13835117
I would suspect that the query result limit is a limit set for the database in general.
You can try to change the limit, but it can case some performance issue if user starts a report without criteria or advance search with week criteria as last modified on by date with an ending actual day >D
it can case very huge database load and can case a crash of method server based on low memory.
btw you can try to change the limit by following article CS26116 - The returned query result has exceeded the query limit
PetrH
Hi @FM_13835117,
Anurag
I have used the format shown below to get results in the browser but want to use an OData connector and can't figure out which endpoint connector to use and how in ThingWorx. I assume that "FolderContents" would go in the expand parameter. Maybe the Get Containers by ID?
