Is there any Direct API to get latest version/ Iteration of object based on View .
@_1647
Reference topic - https://community.ptc.com/t5/Windchill/Report-to-list-WTParts-of-particular-view/m-p/96770#M11366
Hi @Marco_Tosin
I have WTPart on 3.4 with design View
And I have created a new view for the same object and that is on 0.1 Custom View .
So is there any Direct API to get latest version/ Iteration of object based on View .
HelesicPetr
22-Sapphire I
(To:@_1647)
Hi @_1647
generally no. There is no direct api to get latest design view.
I usually use a querySpec to get latest versions and then return the last Design one.
String partNumber = "searchdNumber";
WTPart searchedDesignPart = null;
try
	QuerySpec queryspec;
	queryspec = new QuerySpec();
	int idWTPartObject = queryspec.appendClassList(WTPart.class, true);
	CompositeWhereExpression andCondition = new CompositeWhereExpression(LogicalOperator.AND);
	andCondition.append(new SearchCondition(WTPart.class, WTPart.LATEST_ITERATION, SearchCondition.IS_TRUE), new int[]{idWTPartObject});
	andCondition.append(new SearchCondition(WTPart.class, WTPart.NUMBER, SearchCondition.LIKE, partNumber), new int[]{idWTPartObject});
	queryspec.appendWhere(andCondition, new int[]{idWTPartObject, idWTPartObject});
	queryspec.appendOrderBy(new OrderBy(new ClassAttribute(WTPart.class, WTPart.MODIFY_TIMESTAMP), false), new int[]{0});
	QueryResult resPart = PersistenceHelper.manager.find((StatementSpec) queryspec);
	while (resPart.hasMoreElements())
		Object obj[] = (Object[]) resPart.nextElement();
		WTPart part = (WTPart) obj[0];
		if (part.getViewName().equalsIgnoreCase("Design"))
			searchedDesignPart = part;
} catch (WTException e)
	e.printStackTrace();
PetrH
6 REPLIES 6
HelesicPetr
22-Sapphire I
(To:@_1647)
Hi @_1647
try
PetrH
@_1647
(To:HelesicPetr)
Hi HelesicPetr,
Thank you for help.
Actually I want to get latest iteration of  each view of same object.
HelesicPetr
22-Sapphire I
(To:@_1647)
Hi @_1647
So where is the problem to get all latest version/iterations of each view by the query I've provided?
PetrH
@_1647
(To:HelesicPetr)
Hi HelesicPetr,
Thank you.
Actually your advance query helped alot to get latest iteration of each view.
Thank you again for your efforts and query.
As usual, @HelesicPetr is correct.  There is no getLatestWTPartAtView method. You have to write your own.
I came up with what I think is a fairly simple method that accepts two arguments, WTPart number and View name.
The method gets the desired view using a simple QuerySpec.
If the QuerySpec returns a View (perhaps the view name entered does not exist) the View is used in a second QuerySpec that uses the View and the WTPart number.
The trick is at use order by to set the order of the QueryResult such that the first object in the QueryResult is the object you want.  You simply return that first object.  No need to use a while loop.
In the images below I show the order the iterations occur in the QueryResult.
Latest rev.iteration to first rev.iteration
Now, suppose I want the latest version first but with first iteration, B.1, B.2, B.3, A.1, you get the idea.
I simply flip the sort order, and I get the new ordering.
If I want A.1 first (first iteration to latest iteration) I flip the sort order again and I get the results I want.
David
@_1647
(To:d_graham)
Thank D_graham,
For your detailed explanation about results.
It was very helpful to understand outputs.
