My Requirement is to read a (CR)text box value, when Clicked to fetch the values, I have to show a Dropdown list of (CN's) associated to it.
I'm just trying to read the values first.
<html>
<head>
<script>
var request;
function sendInfo() {
var v = document.vinform.t1.value;
var url = "http://Server/Windchill/servlet/odata/v1/ProjFolder/EndpointName?%24count=false";
if (window.XMLHttpRequest) {
request = new XMLHttpRequest();
} else if (window.ActiveXObject) {
request = new ActiveXObject("Microsoft.XMLHTTP");
try {
request.onreadystatechange = getInfo;
request.open("GET", url, true);
request.send();
} catch (e) {
alert("Unable to connect to server");
function getInfo() {
if (request.readyState == 4) {
var val = request.responseText;
document.getElementById('amit').innerHTML = val;
</script>
</head>
<body>
<marquee>
<h1>This is an example of ajax</h1>
</marquee>
<form name="vinform">
<input type="text" name="t1">
<input type="button" value="ShowTable" onClick="sendInfo()">
</form>
<span id="amit"> </span>
</body>
</html>
I'm trying to read required JSON tags from the output and pass them to the Dropdown values to select.
@HelesicPetr any idea on this?
Hello @Manoj_Dokku4
For JSP pages I use taglibs that can be used in windchill Wizards
so I can build a dropdown selection (ComboBox)
<%@ taglib prefix="wrap" uri="http://www.ptc.com/windchill/taglib/wrappers" %>
//search for a list in the ComboBox
List<String> order_internal_vals = AVCommands.getSubTypePartAttributesforcomboBox(); // my own java function
request.setAttribute("order_display_vals", order_internal_vals); // save output in a request for display list
request.setAttribute("order_internal_vals", order_internal_vals); // save output in a request internal list
<wrap:comboBox id="orderPart2" name="orderPart2" multiSelect="false" size="1"
displayValues="${order_display_vals}"
internalValues="${order_internal_vals}"
onchange="selectProject('orderPart2','zipProject2')" editable="true"/>
<script type="text/javascript">
function selectProject(lokotable, projectTable) {
var comboLokomotive = document.getElementById(lokotable);
if (comboLokomotive != null && comboLokomotive != undefined) {
var index = comboLokomotive.selectedIndex;
//itemValue = comboLokomotive.options[index].value;
setValueProject(index, projectTable);
function setValueProject(value, projectTable) {
var comboProject = document.getElementById(projectTable);
if (comboProject != null && comboProject != undefined) {
comboProject.selectedIndex = value;
</script>
Maybe it can help you
PetrH
Hello @Manoj_Dokku4
</script>
PetrH
Hi - first, take out that activexobject code. Obsolete and confusing. Next, replace EndpointName with something real. Try an experiment at
server/Windchill/netmarkets/html/wrs/doc.html
A small amount of trial-and-error on that site tells me that a working request is GET:
server/Windchill/servlet/odata/v5/ChangeMgmt/ChangeNotices?%24count=false
You need to send that with a header of accept: application/json because {mumble}
PTC has a document describing WRS (Windchill Rest Services). Here is the 2.2 version (there is a 2.3 version but I don't have the link handy).
cheers -- Rick
