Mapping attributes to create a report for Tasks
mariaSutton
I am trying to create a report that returns a list of task with the following columns:
  1. Work Item
  2. Created On (Date)
  3. Initiated by
  4. Task Due Date/Deadline - found under Task > Template View > Deadline
  5. Object Priority - found under Task > Template View > Priority
  6. Task Name
  7. Trip Count
  8. Accepted date - found under Task > Task History > Performed On
  9. Completed By
  10. Date Completed - found under Task > Process Status > Date Completed
  11. State
  12. Context
  13. Last Modified
I have been able to narrow down the type/tables these properties are coming from but I am having trouble matching them to the correct attribute.
The Resource for reporting was very helpful but I was not able to find mapping for some of these  properties.
I also used jcaDebug=1 to gather detail information. This helps me narrow down the table but it does not help map the attribute. ColumnID value doesnt match to an attribute name in the type/table/Row Object.
If you have any resources to show the relationships between tables/types and how to link them, that would be great. For example, what is the best way to link
WfAssignmentEventAudit to obtain the actionPerformedOn value for a task?
TIA!
1 REPLY 1
Fadel
23-Emerald I
(To:mariaSutton)
what tables you need to link ?maybe you can take a look at https://www.ptc.com/en/support/article/CS167392
Fede
