Version: Windchill 12.1
Use Case: Matching WTPart and EPMDocument numbers when using Save As
Description:
Hi all,
We currently have WTPart and EPMDocument subtypes which receive auto generated numbers, snips of the OIRs below...
WTPart:
<!-- Set the number to M01234567 format -->
<AttrValue id="number" algorithm="com.ptc.windchill.enterprise.revisionControlled.server.impl.NumberGenerator">
<Arg>M</Arg>
<Arg>{GEN:wt.enterprise.SequenceGenerator:BOM_GROUP_seq:7:0}</Arg>
</AttrValue>
<AttrConstraint id="number" algorithm="com.ptc.core.rule.server.impl.GatherAttributeConstraints">
<Value algorithm="com.ptc.core.rule.server.impl.GetServerAssignedConstraint"/> <!-- Get the server to generate a number -->
<Value algorithm="com.ptc.core.rule.server.impl.GetHiddenConstraint"/> <!-- Hide from the user (have to leave it modifiable so that auto associate works correctly) -->
</AttrConstraint>
EPMDocument:
<Arg>M</Arg>
</AttrValue>
<Value algorithm="com.ptc.core.rule.server.impl.GetImmutableConstraint"/>
</AttrConstraint>
The intention with these is that the WTPart and EPMDocument have the same number, usually a user will achieve this by either:
This breaks however when a user tries to duplicate an existing WTPart and associated EPMDocument through Save As, as they each get a unique number (e.g. M0001001 & M0001002), requiring some tedious manual renumbering of objects, and we just have to accept that every alternate number won't be used.
It makes sense why OIR gives them different numbers, as it's considering each new object in isolation, and doesn't know there's another object being duplicated at the same time. I've had a look at writing a new RuleAlgorithm to try and capture this, but it seems the only arguments it receives is those that are provided through the OIR XML, and the container, no reference to the other objects that are part of the Save As collection.
A few possible options:
Any other ideas?
Thanks in advance.
Graham, hi
I figure out how to do this using only OIRs.
I start with WTPart and Owner associated CAD Doc that have different numbers. The starting numbers are irrelevant.
I select Save As from the WTPart's action menu and then I include the CAD Doc.
I select Ok and a new WTPart and CAD Doc are created both having the same number. Well, almost the same, the CAD Doc also has the ".PRT" on the end of its number 😊
So, this is possible to do using OIRs.
David
what is the configuration to be done in OIR to achieve this functionality
Hi @GrahamV,
Anurag
