In Windchill, the "Material Type" attribute of a Part or Product is not editable through the user interface (UI), which aligns with our expected system behavior. However, we have observed that when updating Parts or Products via the Importable Spreadsheet functionality, it is currently allowing updates to the "Material Type" attribute.
Is it possible to customize the behavior such that, during spreadsheet import, if a change to the "Material Type" is detected, the system blocks the import and throws an appropriate error?
Should be be feasible using listener , take a look at
https://www.ptc.com/en/support/article/CS43313
and https://www.ptc.com/en/support/article/CS21378
Hi @SM_11016017 ,
If so, please mark the appropriate reply as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
