Migrating WTDocuments to that target system with some added or extra attributes.
aachanta
Hi All,
We are migrating WTDocument without using WBM to Windchill 11 system.
We have now added some extra attributes (soft attributes) to the WTDocument and then we are trying to migrate the same WTDocument once again. Can anyone suggest me like how would I be migrating it ?
Is it using LoadFromFIle or should I be developing a utility for the same. If yes can anyone share me some code snippet for the same. Thanks in advance.
Best Regards,
Aditya
But what if there are many WTDocuments in the system, will LoadFromFile still be a feasible option to load new attributes on top of the existing WTDocuments.
WTDocument objects included in load file are loaded as new iterations if number already exists ( refer to CS )
Kindly let me know if there is any other way apart from LoadFromFile..
OOTB no. You must write some custom loader or SQL script.
6 REPLIES 6
Hi
Without deleting your first load ?
Hi Vincent,
Yes without deleting the WTDocument.
We wish to load the same WTDocument with some extra attributes. So how would I be doing it ? Can you please let me know about it.
Thanks and Regards,
Aditya
See CS24607, it may help
Vincent.
Hi Vincent,
Yes I had gone through this case.
Aditya
Aditya
venki_babu
(To:aachanta)
Purge and delete the old iterations of the docs and now upload the docs with new attributes
