Query spec for multiple objects
TG_10272716
I wrote a SELECT statement that basically queries all Change Activities for all Change Orders (please ignore the * selector for now):
SELECT
FROM WTCHANGEORDER2
INNER JOIN INCLUDEDIN2 ON WTCHANGEORDER2.branchiditerationinfo = INCLUDEDIN2.BRANCHIDA3A5
INNER JOIN WTCHANGEACTIVITY2 ON INCLUDEDIN2.BRANCHIDA3B5 = WTChangeActivity2.branchiditerationinfo
Now I would like to convert this to a Windchill QuerySpec.
What I am trying to do is to get attributes for both the Change Activity and the Change Order. For now I used the * selector but I would like to select attributes from WTChangeActivity2 and WtChangeOrder2.
As of my intuition, you need to specify an "output" class for your query spec, so what class or type those objects from the Query spec belong to but in my case this would be mixed because I need attributes from both types.
Is there a way how I can do this or do I need to split my query up (i.e. first query all Change Orders and then query all Change Activities per Change Order)
Thanks in advance and best regards
HelesicPetr
(To:TG_10272716)
Hello @TG_10272716
Here is example, how to search object based on EPMDocument class and IBA value
Class searchClass = EPMDocument.class;
String searchIBA = "IDNameIBA";
String seachVALUE = "value";
QuerySpec queryspec;
try
queryspec = new QuerySpec();
queryspec.setAdvancedQueryEnabled(true);
int indexObjectEPM = queryspec.appendClassList(searchClass, true);
int indexObjectSTRV = queryspec.appendClassList(StringValue.class, true);
int indexObjectIBA = queryspec.appendClassList(StringDefinition.class, true);
SearchCondition condition17 = new SearchCondition(
				searchClass, WTAttributeNameIfc.ID_NAME,
				StringValue.class, "theIBAHolderReference.key.id");
condition17.setOuterJoin(SearchCondition.LEFT_OUTER_JOIN);
queryspec.appendWhere(condition17,
											new int[]{indexObjectEPM,
															indexObjectSTRV});
queryspec.appendAnd();
				StringValue.class, "definitionReference.key.id",
				StringDefinition.class, WTAttributeNameIfc.ID_NAME);
											new int[]{indexObjectSTRV,
															indexObjectIBA});
CompositeWhereExpression andCondition = new CompositeWhereExpression(LogicalOperator.AND);
andCondition.append(new SearchCondition(StringDefinition.class,
																				StringDefinition.NAME,
																				SearchCondition.LIKE,
																				searchIBA), new int[]{indexObjectIBA});
queryspec.appendWhere(andCondition, new int[]{indexObjectIBA, indexObjectIBA});
andCondition.append(new SearchCondition(StringValue.class,
																				StringValue.VALUE,
																				seachVALUE), new int[]{indexObjectIBA});
queryspec.appendWhere(andCondition, new int[]{indexObjectSTRV, indexObjectSTRV});
andCondition.append(new SearchCondition(searchClass,
																				"iterationInfo.latest",
																				"TRUE"), new int[]{indexObjectEPM});
queryspec.appendWhere(andCondition, new int[]{indexObjectEPM});
queryspec.appendOrderBy(new OrderBy(new ClassAttribute(searchClass, "master>number"), false), new int[]{0});
queryspec.appendOrderBy(new OrderBy(new ClassAttribute(searchClass, "versionInfo.identifier.versionSortId"), false), new int[]{0});
QueryResult queryRes = PersistenceServerHelper.manager.query(queryspec);
  PetrH
HelesicPetr
(To:TG_10272716)
Hi @TG_10272716
Yes there is a way..
On Monday I will send an example how to use inner join in the QuerySpec if no one is faster. .
PetrH
Hi @HelesicPetr,
thank you for your reply, I would greatly appreciate your help.
Best regards
HelesicPetr
(To:TG_10272716)
Hello @TG_10272716
try
															indexObjectSTRV});
															indexObjectIBA});
																				StringValue.VALUE,
  PetrH
Hello @HelesicPetr, thanks for the example.
Just for my understanding; if I use SearchCondition.NO_OUTER_JOIN instead of SearchCondition.LEFT_OUTER_JOIN does this equal a regular (inner) join or a full join?
Best regards
HelesicPetr
(To:TG_10272716)
Hi @TG_10272716
Good question,
Try it. I've never thought about it.
PetrH
