REST API POST method to Upload Primary Content to Document
MT_11904685
I am trying to upload the primary content to a document using REST API. I found information on knowledge hub to do it using Upload Stage 1, Upload Stage 2, Upload Stage 3 actions. I am facing issue while stage 2 action as it is not available in windchill rest services(screenshot attached). I am wondering if it is possible to customize the Document Management domain to perform POST action to upload document primary content directly through rest api. Any hint or assistance will be greatly appreciated.
Thanks in advance for time and consideration.
tm-4
(To:MT_11904685)
The batch request which i posted, will create a document with "helloworld.txt" text file as primary content. No further actions needed . If there is other file type needed to be added as primary content, then you need to write some code to serialize the file. Below is the code snippet with okhttp client . The code will create a document in windchill with a excel file as primary content.
okhttp3.MultipartBody.Builder batchBuilder =
                new okhttp3.MultipartBody.Builder("batch").setType(okhttp3.MultipartBody.MIXED);
        // Changeset part
        okhttp3.MultipartBody.Builder changesetBuilder =
                new okhttp3.MultipartBody.Builder("changeset").setType(okhttp3.MultipartBody.MIXED);
        // Changeset part
        okhttp3.MultipartBody.Builder contenttBuilder =
                new okhttp3.MultipartBody.Builder("ContentSeparator").setType(okhttp3.MultipartBody.FORM);
        // First part of changeset
        changesetBuilder.addPart(
                Headers.of(
                        "Content-ID", "1",
                        "Content-Transfer-Encoding", "binary"),
                RequestBody.create(
                        "POST Documents HTTP/1.1\n"
                                + "Content-Type: application/json\n\n"
                                + "{\n"
                                + "  \"Name\": \"Created Through PostMan\",\n"
                                + "  \"@odata.type\": \"PTC.DocMgmt.MyDocSubtype\",\n"
                                + "  \"Context@odata.bind\": \"Containers('OR:wt.pdmlink.PDMLinkProduct:XXXXXX')\",\n"
                                + "  \"Folder@odata.bind\": \"Folders('OR:wt.folder.SubFolder:XXXXXX')\",\n"
                                + "  \"Attr1\": {\n"
                                + "        \"Value\": \"EN\"\n"
                                + "      },\n"
                                + "       \"Attr2\": {\n"
                                + "        \"Value\": \"1\"\n"
                                + "      },\n"
                                + "      \"Attr3\": \"10\"\n"
                                + "}\n",
                        MediaType.parse("application/http")));
        // Second part of changeset
                Headers.of(
                        "Content-ID", "2",
                RequestBody.create(
                        "POST $1/PTC.DocMgmt.CheckOut HTTP/1.1\n"
                                + "{\n"
                                + "\n"
                                + "}\n"
                                + "\n",
        MediaType MEDIA_TYPE_EXCEL =
                MediaType.parse("application/vnd.openxmlformats-officedocument.spreadsheetml.sheet");
        URI propertyURI =
                GenericTest.class
                        .getClassLoader()
                        .getResource("PartLoaderTemplate_LoadTesting.xlsx")
                        .toURI();
        String excelpath = Paths.get(propertyURI).toString();
        File excelFile = new File(excelpath);
        contenttBuilder.addFormDataPart(
                "primaryFilepathInput",
                excelFile.getName(),
                RequestBody.create(MEDIA_TYPE_EXCEL, excelFile));
        Buffer rb = new Buffer();
        ((RequestBody) contenttBuilder.build()).writeTo(rb);
                Headers.of(
                        "Content-ID", "3",
                RequestBody.create(
                        "PUT $2/PrimaryContent HTTP/1.1\n"
                                + "Content-Type: multipart/form-data; boundary=ContentSeparator\n\n"
                                + rb.readUtf8(),
        // Fourth part of changeset
                Headers.of(
                        "Content-ID", "4",
                RequestBody.create(
                        "POST $2/PTC.DocMgmt.CheckIn HTTP/1.1\n"
                                + "{\n"
                                + "\n"
                                + "}\n"
                                + "\n",
        // Add changeset to batch
        batchBuilder.addPart(changesetBuilder.build());
        Request request =
                new Request.Builder()
                        .url("https://XXXXXXX/Windchill/servlet/odata/v5/DocMgmt/$batch")
                        .post(batchBuilder.build())
                        .header("CSRF_NONCE", "XXXXXXXXXX")
                        .addHeader("Content-Type", "multipart/mixed;boundary=batch")
                        .addHeader("accept", "application/json;odata.metadata=none")
                        .addHeader(
                                "Authorization",
                                "Basic "
                                        + Base64.getEncoder()
                                        .encodeToString(
                                                ("USERNAME" + ":" + "PASSWORD").getBytes(StandardCharsets.UTF_8)))
                        .build();
        try (Response response = client.newCall(request).execute()) {
            // Buffer b = new Buffer();
            // response.request().body().writeTo(b);
            // System.out.println("Req Body: " + b.readUtf8());
            assertAll(() -> assertTrue(response.isSuccessful()), () -> assertNotNull(response.body()));
            String responseBody = response.body().string();
            LOGGER.trace("responseBody = {}", responseBody);
            Pattern pattern = Pattern.compile("boundary=(.+)");
            Matcher matcher = pattern.matcher(responseBody);
            String boundry = "";
            while (matcher.find()) {
                boundry = matcher.group(1);
            LOGGER.trace("boundry = {}", boundry);
Hi @MT_11904685
Thank you for your question!
Please consider adding screenshot(s) to better understand what you are trying to do in your process.
Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
Thank you for your participation and please let me know if you need further assistance!
Best regards,
Catalina
PTC Community Moderator
PTC
tm-4
(To:MT_11904685)
To create a document with content, i suggest to use a batch mode. Refer example below,
Body
--batch
Content-Type: multipart/mixed;boundary=changeset
--changeset
Content-ID: 1
Content-Type: application/http
Content-Transfer-Encoding:binary
  "Name": "Created Through PostMan",
  "@odata.type": "PTC.DocMgmt.MyDocType",
  "Context@odata.bind": "Containers('OR:wt.pdmlink.PDMLinkProduct:xxxxxxx')",
  "Folder@odata.bind": "Folders('OR:wt.folder.SubFolder:xxxxxxxx')",
  "DocumentLanguage": {
        "Value": "EN"
       "ClassificationLevel": {
        "Value": "1"
      "SubType": "10"
--changeset
Content-ID: 2
--changeset
Content-ID: 3
--ContentSeparator
Content-Disposition: form-data; name="primaryFilepathInput";filename="helloworld.txt"
Content-Type: text/plain
Hello, World!
--ContentSeparator--
--changeset
Content-ID: 4
--changeset--
--batch--
Thank you for the response. if i understand it right, the document  will be created in the batch request or i have to create it in separate post request. Also I have uploaded the text file using Stage-1, 2, 3 Action available in Windchill rest services module. The problem I am facing now is when I change the data file from simple text file then this method does not work. I would really appreciate your help. thank you.
        "Value": "EN"
        "Value": "1"
      "SubType": "10"
tm-4
(To:MT_11904685)
        // Changeset part
        // Changeset part
                Headers.of(
                        "Content-ID", "1",
                RequestBody.create(
                                + "{\n"
                                + "  \"Attr1\": {\n"
                                + "      },\n"
                                + "       \"Attr2\": {\n"
                                + "      },\n"
                                + "}\n",
                Headers.of(
                        "Content-ID", "2",
                RequestBody.create(
                                + "{\n"
                                + "\n"
                                + "}\n"
                                + "\n",
        URI propertyURI =
                GenericTest.class
                        .getClassLoader()
                        .toURI();
                Headers.of(
                        "Content-ID", "3",
                RequestBody.create(
                                + rb.readUtf8(),
                Headers.of(
                        "Content-ID", "4",
                RequestBody.create(
                                + "{\n"
                                + "\n"
                                + "}\n"
                                + "\n",
        Request request =
                        .addHeader(
                                "Authorization",
                                "Basic "
                                        .encodeToString(
                        .build();
