Feb 10, 2025 6:29 AM UTC
REST + PartsLink
I am using Windchill PDMLink Release 12.1 and Datecode with CPS 12.1.2.2
I cannot update the classification of a Part using Windchill REST Services in Windchill PartsLink
The PartsLink binding attribute internal name is: CLASS
It is defined in a subclass of WTPart called StandandPart
POST http://fihel1-sp113wnd.mcint.local/Windchill/servlet/odata/v5/ProdMgmt/Parts('OR:wt.part.WTPart.8024517512')/PTC.ProdMgmt.StandardPart
JSON:
"CLASS": {
"ClfNodeInternalName": "class0443"
No matter what I do, I get an error: 'CLASS' can not be mapped as a property or an annotation.
Feb 10, 2025 7:23 AM UTC
Articles:
dgarcia12-AmethystAuthor
Feb 10, 2025 8:08 AM UTC
Thank you Vladimir
CS299533 does not apply in my case.
I tried the solution in CS294555 but I get the same error..
Emeritus
Feb 17, 2025 6:35 AM UTC
Hi @dgarcia,
Thank you for your question.
Your post has not received a response since a few days. I am replying to raise awareness. Hopefully, another community member will be able to help.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Vivek N
Community Moderation Team
