RemoteMethodServer.invoke() called on default method server from within method server
MA_10111591
Error message "RemoteMethodServer.invoke() called on default method server from within method server! Bad loopback code!" is displayed in MethodServer.log during part creation.
Need a suggestion, to fix this Error message.
I've attached the code snippet below for the reference, so pelase check it.
Code Snippet:
java.util.Iterator<CustomClassificationBean> iterator = getBean.iterator();
while(iterator.hasNext()){
CustomClassificationBean partBean = (CustomClassificationBean)iterator.next();
userName = partBean.getUserName();
}catch(Exception e){
e.printStackTrace();
RemoteMethodServer remoteMethodServer = null;
GatewayAuthenticator auth = null;
Class[] argTypes = new Class[]{java.util.Vector.class};
Object[] argList = new Object[]{getBean};
auth= new GatewayAuthenticator();
remoteMethodServer = RemoteMethodServer.getDefault();
auth.setRemoteUser(userName);
remoteMethodServer.setAuthenticator(auth);
remoteMethodServer.setUserName(userName);
responseData =(String) remoteMethodServer.invoke("createPart", "com.test.customService", null, argTypes, argList);
2 REPLIES 2
Read the following article - "Error message "RemoteMethodServer.invoke() called on default method server from within method server! Bad loopback code!" is displayed in MethodServer.log during Upgrade process : Windchill PDMLink 10.1": https://www.ptc.com/en/support/article/CS184974
MA_10111591
(To:VladimirN)
Thanks for your suggestion.
I've already reviewed this article, but i didn't get more information.
is there any way to avoid this issue in the custom code ?
kindly share your suggestion.
