Restrict certain users from using a Customization tool
hsha1102
11-Garnet
Hello All,
We have one functionality "Part Number Generator" in Customization tab which helps the users to have a certain set of part numbers in store for them if they want to create new WTParts.
Now I want to restrict certain users from using this functionality, either hide the functionality or disable the option.
Please instruct me on how to proceed.
P.S: I have done customization in Java code but not so much with the jsp and js and all.
Thanks and Regards,
Hari R
You have to create an action validation filter. I attached you an example to hide the action for all users except org and site admin.
xconf
<Service context="default" name="com.ptc.core.ui.validation.SimpleValidationFilter" targetFile="codebase/service.properties">
   <Option requestor="null"
           selector="hideForNonOrgOrSiteAdmins"
           serviceClass="xxx.validators.HideFromNonOrgOrSiteAdminActionValidation"/>
</Service>
Java Class
package xxx.validators;
import com.ptc.core.ui.validation.DefaultSimpleValidationFilter;
import com.ptc.core.ui.validation.UIValidationCriteria;
import com.ptc.core.ui.validation.UIValidationKey;
import com.ptc.core.ui.validation.UIValidationStatus;
import lombok.extern.slf4j.Slf4j;
 * Hides an action for all user except Org and Site administrators
@Slf4j
public class HideFromNonOrgOrSiteAdminActionValidation extends DefaultSimpleValidationFilter {
  @Override
  public UIValidationStatus preValidateAction(UIValidationKey uiValidationKey,
                                              UIValidationCriteria uiValidationCriteria) {
    if (log.isTraceEnabled()) {
      log.trace("  validtionKey -> " + uiValidationKey);
      log.trace("  validationCriteria -> " + uiValidationCriteria.toString());
    UIValidationStatus uiValidationStatus = UIValidationStatus.HIDDEN;
    if (uiValidationCriteria.isSiteAdmin() || uiValidationCriteria.isOrgAdmin()) {
      uiValidationStatus = UIValidationStatus.ENABLED;
    return uiValidationStatus;
 Include filter for action (name is defined in xconf property)
<action ajax="page"
                name="xxx">
        <command class="xxx"
                 method="execute"
                 url="xxx.jsp"
                 windowType="popup"/>
        <includeFilter name="hideForNonOrgOrSiteAdmins"/>
</action>
2 REPLIES 2
xconf
</Service>
Java Class
@Slf4j
  @Override
<action ajax="page"
                name="xxx">
                 method="execute"
                 url="xxx.jsp"
</action>
Hello @BjoernRueegg ,
Thanks for the response. It is working.
Hari R
