I need to retrieve the API of all objects affected by change notifications in WTpart through programming, because I need to control whether the WTPart objects of the affected objects already have other changes when creating a new ECN. If so, the current change will be canceled and the customer will be prompted that there are already other changes in the objects. Please complete them first before initiating the change
Thank you very much for your reply. My issue has been resolved. thank you
