Solution : Windchill Data Deletion Utility for Bulk Removal of Windchill objects.
KP_11714888
package ext.utility
import wt.associativity.EquivalenceLink;
import wt.change2.WTChangeActivity2;
import wt.change2.WTChangeIssue;
import wt.change2.WTChangeOrder2;
import wt.change2.WTChangeRequest2;
import wt.doc.WTDocument;
import wt.epm.EPMDocument;
import wt.epm.structure.EPMDescribeLink;
import wt.epm.structure.EPMMemberLink;
import wt.epm.structure.EPMReferenceLink;
import wt.fc.Persistable;
import wt.fc.PersistenceHelper;
import wt.fc.PersistenceServerHelper;
import wt.fc.QueryResult;
import wt.maturity.PromotionNotice;
import wt.method.RemoteAccess;
import wt.method.RemoteMethodServer;
import wt.part.WTPart;
import wt.part.WTPartAlternateLink;
import wt.part.WTPartDescribeLink;
import wt.part.WTPartUsageLink;
import wt.query.QuerySpec;
import wt.session.SessionServerHelper;
import wt.util.WTException;
import wt.util.WTPropertyVetoException;
import wt.vc.VersionControlHelper;
import wt.vc.wip.WorkInProgressHelper;
import wt.vc.wip.Workable;
import wt.workflow.work.WorkItem;
public class DataDeletionUtility implements RemoteAccess {
	 * Through this utility we are deleting data from windchill. The objects targeted are:
	 * 1.Part Usage Links
	 * 2.Part Describe Links
	 * 3.Equivalence Links
	 * 4.Part Alternate Links
	 * 5.EPM Describe links
	 * 6.EPM Uses links
	 * 7.EPM Reference Links
	 * 8.Change Notices
	 * 9.Change Requests
	 * 10.Change Activity
	 * 11.Problem Reports
	 * 12.Promotion Requests
	 * 13.EPM Documents
	 * 14.WTParts
	 * 15.WTDocuments
	 * Run this command on windchill shell:
	 * windchill ext.utility.DataDeletionUtility
	 * to run this utility
	public static RemoteMethodServer getMS() {
		return RemoteMethodServer.getDefault();
	public static void main(String[] argv) {
		try {
			RemoteMethodServer rms = getMS();
			rms.setUserName("wcadmin");
			rms.setPassword("wcadmin");
			rms.invoke("run", "ext.utility.DataDeletionUtility", null, null, null);
		} catch (Exception e) {
			e.printStackTrace();
		} finally {
			System.exit(0);
	public static void run() throws Exception {
		Boolean enforced = SessionServerHelper.manager.isAccessEnforced();
		SessionServerHelper.manager.setAccessEnforced(false);
		deleteChangeObjects();
		deleteEqLinks();
		deletePartUsageLinks();
		deleteDescribeLinks();
		deletePartAlternateLinks();
		deleteEPMDescribeLinks();
		deleteEPMUsesLinks();
		deleteEPMReferenceLinks();
		deleteParts();
		deleteDocuments();
		deleteEPMDocument();
		SessionServerHelper.manager.setAccessEnforced(enforced);
	@SuppressWarnings("deprecation")
	public static void deletePartUsageLinks() throws Exception {
		System.out.println("Deleting part usage links..");
		QuerySpec querySpec = new QuerySpec(WTPartUsageLink.class);
        QueryResult links = PersistenceHelper.manager.find(querySpec);
        while (links.hasMoreElements()) {
        	Persistable link = (Persistable) links.nextElement();
            try {
                System.out.println("Deleting link: " + link);
                PersistenceServerHelper.manager.remove(link);
            } catch (WTException e) {
                System.err.println("Failed to delete link: " + link);
	public static void deleteDescribeLinks() throws Exception {
		System.out.println("Deleting part describe links..");
		QuerySpec querySpec = new QuerySpec(WTPartDescribeLink.class);
            try {
	public static void deleteEqLinks() throws Exception {
		System.out.println("Deleting equivalence links..");
		QuerySpec querySpec = new QuerySpec(EquivalenceLink.class);
        QueryResult eqlinks = PersistenceHelper.manager.find(querySpec);
        while (eqlinks.hasMoreElements()) {
        	Persistable link = (Persistable) eqlinks.nextElement();
            try {
	public static void deletePartAlternateLinks() throws Exception {
		System.out.println("Deleting part alternate links..");
		QuerySpec querySpec = new QuerySpec(WTPartAlternateLink.class);
            try {
	public static void deleteEPMDescribeLinks() throws Exception {
		System.out.println("Deleting EPM describe links..");
		QuerySpec querySpec = new QuerySpec(EPMDescribeLink.class);
        QueryResult epmDescLinks = PersistenceHelper.manager.find(querySpec);
        while (epmDescLinks.hasMoreElements()) {
        	Persistable link = (Persistable) epmDescLinks.nextElement();
            try {
                System.err.println("Failed to delete epm desc link: " + link);
	public static void deleteEPMReferenceLinks() throws Exception {
		System.out.println("Deleting EPM ref links..");
		QuerySpec querySpec = new QuerySpec(EPMReferenceLink.class);
        QueryResult epmRefLinks = PersistenceHelper.manager.find(querySpec);
        while (epmRefLinks.hasMoreElements()) {
        	Persistable link = (Persistable) epmRefLinks.nextElement();
            try {
                System.err.println("Failed to delete epm ref link: " + link);
	public static void deleteEPMUsesLinks() throws Exception {
		System.out.println("Deleting EPM uses links..");
		QuerySpec querySpec = new QuerySpec(EPMMemberLink.class);
        QueryResult EPMUsesLinks = PersistenceHelper.manager.find(querySpec);
        while (EPMUsesLinks.hasMoreElements()) {
        	Persistable link = (Persistable) EPMUsesLinks.nextElement();
            try {
                System.err.println("Failed to delete epm uses link: " + link);
	public static void deleteChangeObjects() throws Exception {
		System.out.println("Deleting change objects..");
		QuerySpec querySpec1 = new QuerySpec(WTChangeOrder2.class);
        QueryResult CN = PersistenceHelper.manager.find(querySpec1);
        while (CN.hasMoreElements()) {
        	Persistable persCN = (Persistable) CN.nextElement();
            try {
                System.out.println("Deleting CN: " + persCN);
                PersistenceServerHelper.manager.remove(persCN);
                System.err.println("Failed to CN: " + persCN);
        QuerySpec querySpec2 = new QuerySpec(WTChangeRequest2.class);
        QueryResult CR = PersistenceHelper.manager.find(querySpec2);
        while (CR.hasMoreElements()) {
        	Persistable persCR = (Persistable) CR.nextElement();
            try {
                System.out.println("Deleting CR: " + persCR);
                PersistenceServerHelper.manager.remove(persCR);
                System.err.println("Failed to CR: " + persCR);
        QuerySpec querySpec3 = new QuerySpec(WTChangeActivity2.class);
        QueryResult CA = PersistenceHelper.manager.find(querySpec3);
        while (CA.hasMoreElements()) {
        	Persistable persCA = (Persistable) CA.nextElement();
            try {
                System.out.println("Deleting link: " + persCA);
                PersistenceServerHelper.manager.remove(persCA);
                System.err.println("Failed to delete link: " + persCA);
        QuerySpec querySpec7 = new QuerySpec(WorkItem.class);
        QueryResult workItem = PersistenceHelper.manager.find(querySpec7);
        while (workItem.hasMoreElements()) {
        	Persistable task = (Persistable) workItem.nextElement();
            try {
                System.out.println("Deleting tasks: " + task);
                PersistenceServerHelper.manager.remove(task);
                System.err.println("Failed to delete task: " + task);
        QuerySpec querySpec4 = new QuerySpec(WTChangeIssue.class);
        QueryResult problemReports = PersistenceHelper.manager.find(querySpec4);
        while (problemReports.hasMoreElements()) {
        	Persistable pr = (Persistable) problemReports.nextElement();
            try {
                System.out.println("Deleting Problem reports: " + pr);
                PersistenceServerHelper.manager.remove(pr);
                System.err.println("Failed to Problem reports: " + pr);
        QuerySpec querySpec5 = new QuerySpec(PromotionNotice.class);
        QueryResult problemNotice = PersistenceHelper.manager.find(querySpec5);
        while (problemNotice.hasMoreElements()) {
        	Persistable pn = (Persistable) problemNotice.nextElement();
            try {
                System.out.println("Deleting Promotion Notice: " + pn);
                PersistenceServerHelper.manager.remove(pn);
                System.err.println("Failed to Promotion Notice: " + pn);
	public static void deleteEPMDocument() throws WTException {
		System.out.println("Deleting EPM document..");
        QuerySpec querySpec = new QuerySpec(EPMDocument.class);
        QueryResult docs = PersistenceServerHelper.manager.query(querySpec);
        while (docs.hasMoreElements()) {
        	EPMDocument epmdoc1 = null;
            try {
                Persistable epmdoc = (Persistable) docs.nextElement();
                if(epmdoc instanceof EPMDocument) {
                	epmdoc1 = (EPMDocument) epmdoc;
                	QueryResult result = VersionControlHelper.service.allIterationsOf(epmdoc1.getMaster());
                	while(result.hasMoreElements()) {
                			System.out.println("Deleting EPM document: " + epmdoc1.getNumber());
                        Persistable doc2= (Persistable) result.nextElement();
                        if(WorkInProgressHelper.isCheckedOut((Workable) doc2)) {
                            WorkInProgressHelper.service.checkin((Workable) doc2,"Checkin via api");
                        PersistenceHelper.manager.delete(doc2);
        }catch (Exception e) {
        	System.err.println("Failed to delete epm doc: " + epmdoc1.getNumber());
	public static void deleteParts() throws WTException, WTPropertyVetoException {
		System.out.println("Deleting parts..");
        QuerySpec querySpec = new QuerySpec(WTPart.class);
        QueryResult parts = PersistenceServerHelper.manager.query(querySpec);
        while (parts.hasMoreElements()) {
        	WTPart part1 = null;
            try {
            	Persistable part = (Persistable) parts.nextElement();
            	if(part instanceof WTPart) {
					part1 = (WTPart) part;
					QueryResult allIterations = VersionControlHelper.service.allIterationsOf(part1.getMaster());
					while(allIterations.hasMoreElements()) {
						System.out.println("Deleting part: " + part1.getNumber());
						Persistable part2= (Persistable) allIterations.nextElement();
						if(WorkInProgressHelper.isCheckedOut((Workable) part2)) {
							WorkInProgressHelper.service.checkin((Workable) part2,"Checkin via api");
						PersistenceHelper.manager.delete(part2);
                System.out.println("Deleting part: " + ((WTPart)part).getNumber());
                System.err.println("Failed to delete part: " + part1.getNumber());
	public static void deleteDocuments() throws WTException, WTPropertyVetoException {
		System.out.println("Deleting docs..");
		QuerySpec querySpec = new QuerySpec(WTDocument.class);
		QueryResult docq = PersistenceServerHelper.manager.query(querySpec);
		while (docq.hasMoreElements()) {
			WTDocument doc1 = null;
			try {
				Persistable doc = (Persistable) docq.nextElement();
				if(doc instanceof WTDocument) {
					doc1 = (WTDocument) doc;
					QueryResult allIterations = VersionControlHelper.service.allIterationsOf(doc1.getMaster());
						System.out.println("Deleting doc: " + doc1.getNumber());
						Persistable doc2 = (Persistable) allIterations.nextElement();
						PersistenceHelper.manager.delete( doc2);
				System.err.println("Failed to delete doc: " + doc1.getNumber());
3 REPLIES 3
@KP_11714888 thanks. looks good.
This will also delete all the Document-, Change Order-, CAD-Document templates. Probably these should be ignored.
Yeah, you can definitely modify the code based on specific requirements. In my case, I needed to delete everything—including Documents, Change Objects, and CAD templates. Thanks! @BjoernRueegg
I want to delete the link between two documents i.e. WTDocumentDependencyLink based on the given WTDocument.
Can you help me with the how do I get link object here so that i can delete it using PersistenceHelper
