this is similar: https://www.ptc.com/en/support/article/CS342959?source=search
In general I remember the compiledTasks folder as something that can be cleared and rebuilt.
@avillanueva is correct. The infoengine/compiledTasks directory can be removed.
My windchill startup script contains the following, before starting Windchill, for cleaning/clearing caches:
#https://www.ptc.com/en/support/article/CS172572
#This article says to clear the cache which means this "Cleaning caches" needs to happen before
#firing up Windchill
#See also article CS29555 https://www.ptc.com/en/support/article/CS29555
echo Cleaning caches...
rm -rf /opt/ptc/Windchill/Windchill/tomcat/instances/* 2>/dev/null
rm -rf /opt/ptc/Windchill/Windchill/tasks/codebase/com/infoengine/compiledTasks/* 2>/dev/null
rm -rf /opt/ptc/Windchill/Windchill/codebase/wt/workflow/expr/* 2>/dev/null
Hi @JJ_10067340,
Thank you for your question.
It looks like you have some responses from some community members. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
