8-Gravel
August 2, 2024
Update EPMDocument IBA through JAVA
Good evening,
I'm having trouble understanding the process of updating an IBA of an EPMDocument.
I'm trying as it follows:
attributes.put(attributeName, attributeValue);
PersistableAdapter epmObj = new PersistableAdapter(epmDoc, null, null, new UpdateOperationIdentifier());
epmObj.load(attributeName);
epmObj.set(attributeName, attributeValue);
EPMDocument obj = (EPMDocument) epmObj.apply();
PersistenceHelper.manager.modify(obj);
However I didn't get any changes on the attribute itself. I'm guessing that in this case I need to checkout the EPM and do the changes on a working copy of it to persist the changes.
However reading the documentation and other topics I haven't found a clear flow to check-out--> set the attribute and then check-in the object. Can someone give me a hand on this if possible? Thank you kindly for your support
GrahamVAnswer
You are correct, you need to check out the object first, make the modifications, then check in. I think you need something like the below...
doc = (EPMDocument) WorkInProgressHelper.service.checkout(doc, WorkInProgressHelper.service.getCheckoutFolder(), null).getWorkingCopy();
PersistableAdapter pa = new PersistableAdapter(doc, null, Locale.getDefault(), null);
pa.load(attributeName);
pa.set(attributeName, attributeValue);
doc = (EPMDocument) pa.apply();
doc = (EPMDocument) PersistenceHelper.manager.modify(doc);
doc = (EPMDocument) WorkInProgressHelper.service.checkin(doc, "IBA Updated");
Graham
Community Moderator
August 6, 2024
Hi @AK_10639313,
Thank you for your question.
Vivek N
Community Moderation Team.
GrahamV12-AmethystAnswer
Graham
Community Moderator
August 12, 2024
Hello @AK_10639313,
It looks like you have a response from a community member. If it helped to answer your question please mark the reply as the Accepted Solution.
Vivek N.
