Value Properties
CS_10827225
3-Newcomer
Value Properties
Schuetzinger, Christian
Di 28.11, 19:19 Schuetzinger, Christian
Dear PTC Team,
I am currently working on my Masterthesis with the windchill modeler.
Now I am at a point where i can't find sufficient material in the knowlege base.
May I ask you if you can help me with my following problem:
I am currently creating a windchill model for a car body.
Now I want to assingn specific values to the blocks like lenght and weight. How is it possible to give the blocks the real value properties which can be used later on in the CAD enviroment like Creo.
Example one block is the Front end. It shall have the block property h x w x d = 0,1m x 0,2m x 0,02m.
How can I assign them?
I hope you can help me with this issue.
Many Thanks,
Christian Schützinger
1 REPLY 1
Fadel
23-Emerald I
(To:CS_10827225)
Guten Tag Christian,
when you say "creating a windchill model for a car body" ,do you mean that you are creating an EPMDocument using API and you need help with entering values for the model geometry ?
Fede
