I want to customize the version synchronizations for the part, cad and drawing data we use in windchill. I don't want to do this manually. Is it possible to create a flow for this process and take part data codes from users in this flow and synchronize these codes to the most current version in the workflow? If we do the version synchronization process in the workflow, will there be a problem in connecting the data with each other?
Very doable to Synch revisions of WTPart, WTDocument, EPMDocuments automatically in a workflow.
There will not be a problem linking (I guess that’s what you mean by connecting) then WTPart, to the WTDoc and/or EPMDocs (Cad model and Cad drawing).
No idea what you mean by, “take part data codes from user”. 🤷♂️
