Workflow robots and conditionals java code debugging
James62
If for example a System.out.println("some text"); line is used within the java code where does the result show up?
5 REPLIES 5
pwilliams-3
(To:James62)
Look in your BGMS log file.  All workflow tasks run on the BGMS and will therefore print out to that log file.
It's there. Thanks.
Wouldn't know what's BGMS so i marked Randy's reply as correct.
RandyJones
20-Turquoise
(To:James62)
In the method server or background method server logs. For a workflow this will show up in the background method server log (if you have a background method server configured).
lmouchard
(To:James62)
Hi James,
the method server uses log4j. The default configuration file for logging (log4MethodServer.properties)  redirects the standard outputs  to the log file of the method server. See:
log4j.rootLogger=ERROR, stdout, methodServerLogFile, MiscLogEvents
If you are familiar to the use of log4j, you can quite easily configure a new logger for log4J and use it in Java, with different levels (for ex: ERROR, WARNING, INFO, DEBUG)
In your java code, you'll have something like :
org.apache.log4j.Logger LOGGER = Logger.getLogger(YourOwnClass.class);
LOGGER.debug("some text");
LOGGER.warn("some warning");
Configure logger in the log4j property file (log4MethodServer.properties), you then have to define a logger as following, and can change the level without changing your code.
log4j.logger.your.own.package=DEBUG, methodServerLogFile
(replace with your package)
Loic
James62
(To:lmouchard)
"YourOwnClass.class"? "replace with your package"?
Sadly, i have no idea what any of that means, but luckily I'm done with this project and i actually succeeded. Let's just hope i won't touch workflows for a while now.
You should know this didn't fall on fertile land, but thanks anyway.
