how to create part in infoengine using webserice
ukrishnan-3
11-Garnet
Version: Windchill 12.1
Use Case: how to create part in info-engine using webserice
Description:
Are you sure you need InfoEngine? Can't you do it with an OData WRS call?
An entry in this community says that InfoEngine is deprecated.
Hello @ukrishnan-3
It looks like you have some responses from some community members. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Community Moderation Team.
