how to display custom user picker value
CZ_9645217
Dears,
I wrote a customized User Picker according to the Demo, it is working fine under the Creat and Edit modes, but it can't show the selected property value, I think I should need to write some code under the getDataValue method for the ComponentMode.VIEW, how can I make writing this part of the code to be able to display it on the VIEW under getDataValue method. Thank you.
	@Override
	public Object getDataValue(String component_id, Object object, ModelContext mc) throws WTException {
		String attributeId = component_id;
		Object obj = null;
		GUIComponentArray guiArray = new GUIComponentArray();
		if (ComponentMode.CREATE.equals(mode) || ComponentMode.EDIT.equals(mode)) {
			obj = super.getDataValue(attributeId, object, mc);
			if (obj instanceof PickerInputComponent) {
				PickerInputComponent pickerComponent = (PickerInputComponent) obj;
				guiArray.addGUIComponent(pickerComponent);
		} else if (ComponentMode.VIEW.equals(mode)) {
//TODO
		return obj;
Hi @CZ_9645217
You can use Lable (com.ptc.core.components.rendering.guicomponents.Lable)
Label nameComponent = new Label("");
nameComponent.setColumnName(AttributeDataUtilityHelper.getColumnName(component_id, obj, modelContext));
nameComponent.setId(component_id);
nameComponent.setValue(pickerComponent.getValue());
 PetrH
8 REPLIES 8
Hi @CZ_9645217
 PetrH
CZ_9645217
(To:HelesicPetr)
Hi @HelesicPetr
Thank you very much for your prompt reply, it solved my problem!
tspain
6-Contributor
(To:CZ_9645217)
Hi @CZ_9645217,
Could you share your getDataValue method after you were able to get working?   I have spent a couple of days trying to get this to work but I have been unsuccessful.  Thank you.
HelesicPetr
22-Sapphire I
(To:tspain)
Hi @tspain
What is your issue?
Can you get the right value from your attribute?
here is the easiest example:
public Object getDataValue(String component_id, Object object, ModelContext modelContext) throws WTException
Label nameComponent = new Label("My attribute Value");
nameComponent.setValue("My attribute Value");
return nameComponent;
PetrH
tspain
6-Contributor
(To:HelesicPetr)
Hi @HelesicPetr,
Thanks for responding.   My attribute for UID was showing blank on the info page.   I tried your code example and now I am getting UID for the value instead of the actual value.
I noticed in your code that you reference obj instead of object.  How is obj instantiated for ComponentMode.VIEW.  I just used object for my test.
HelesicPetr
22-Sapphire I
(To:tspain)
Hi @tspain
obj = object
You need to read the attribute value from the object. So you need to write code that retrieves the value of the attribute.
PetrH
tspain
6-Contributor
(To:HelesicPetr)
Hi @HelesicPetr,
Thanks again for your help.  I am now able to see the attribute value on the info page.  Below is my code in case it may help someone else.   Also reference CS347200.
Object value = mc.getRawValue();
Label nameComponent = new Label("UID");
nameComponent.setColumnName(AttributeDataUtilityHelper.getColumnName(component_id, object, mc));
nameComponent.setValue(value.toString());
HelesicPetr
22-Sapphire I
(To:tspain)
Hi @tspain
Does your value has a string value? if not then the getRawValue does not work as you expect
use
Label nameComponent = new Label(value );
PetrH
