I have changed in CAPA oir , Im passing attribute value on CAPA name while creating new CAPA but that IBA is not present in Nonconfomance so how can I create CAPA?
Hi @RS_10128209
The IBA should be presented on the new CAPA object. . .
if it is not there, then you can not use this IBA in the OIR or you have to create the IBA on the correct soft type object. CAPARequest...
PetrH
