Can't modify user in Thingworx Composer
GJ_10027434
7-Bedrock
Hi All!
I've had some issues with modifying one particular user in Thingworx Composer, I couldn't update the password, profile picture, etc, however, I was able to update two other users without any issue.
I got the following error messages:
Unable To Update Entity: xyz was modified on 2021-09-30T10:38:10.255Z
Transaction has been marked as a failure for request /Thingworx/Users/xyz
Unable to process import: Unable to update user: xyz
I am using Thingworx Navigate 9.1
slangley
(To:GJ_10027434)
Hi @GJ_10027434.
Are you using Solution Central for migrating projects to other environments?  If so, this could be the cause of the problem if the user was included in the project.  Projects deployed to other systems are not editable.  To correct it in this situation, you would need to remove the user from the project on the source system, publish a new version, then redeploy to the target system.
If this is not the issue, check the logs in \ThingworxStorage\logs for possible causes of the problem.  You might also want to test it with the Administrator account.
Regards.
--Sharon
slangley
(To:GJ_10027434)
Hi @GJ_10027434.
Regards.
--Sharon
