How to enable SSO on Multiple Thingworx Instance with Single Azure Enterprise Application
Velkumar
Hi all,
We have enabled SSO on one of Thingworx Instance. Now we want to implement SSO for multiple Thingworx Instance. Is it possible to use same Ping Fed server and Azure Enterprise Application ?
If yes, please share steps/procedure to implement it.
Thanks in advance
/VR
schauvelin
(To:Velkumar)
From my point of view you can create multiple SP connections (each of one corresponding to one TWX instance).
You will authenticate at the end to the IdP defined in PingFederate.
You just need to redo same steps you did for your first TWX SP configuration but with another name.
Kind regards.
barko
(To:Velkumar)
No. In the PingFederate configuration you define a specific ThingWorx server that will act as the Service Provider.
schauvelin
(To:Velkumar)
Kind regards.
