How to export and import extensions from thingworx UI
arasool2020
8-Gravel
I tried to export and import extensions from thingworx UI but on the target, I am unable to see the extensions in the extensions list. I have attached the procedure document that I followed to perform this activity. Can somebody look into it, if possible please share the article on how to export and import the extensions?
2 REPLIES 2
Hi Abbas
You may follow this article https://www.ptc.com/en/support/article/CS233011
If you still encounter any issue, you may create a case with ThingWorx Platform team.
Arshad
@Arshad  Thanks for your feedback. I will log a PTC case.
