I tried to export and import extensions from thingworx UI but on the target, I am unable to see the extensions in the extensions list. I have attached the procedure document that I followed to perform this activity. Can somebody look into it, if possible please share the article on how to export and import the extensions?
Hi Abbas
You may follow this article https://www.ptc.com/en/support/article/CS233011
If you still encounter any issue, you may create a case with ThingWorx Platform team.
Arshad
