Hello All,
I want to implement SSO on Thingworx(navigate) on Azure Cloud. How should I do that and what are the necessary things I need to configure and where to configure, and all details I need. Any documentation which explain clearly other than PTC docs.
KSM
Hello KSM,
as of Navigate 9.5 Azure AD is also supported and documented. See
Was a bit tricky to configure the Windchill side as well.
best regards,
Stijn
Take a look:
Hi Vladimir,
Thanks for reply,
The link you have provided that shows the configuration of SSO through Ping federate, I need how to configure SSO on AD Azure. and also tell me is PingFederate mandatory for the configuration of SSO.
KSM
Hello KSM,
best regards,
Stijn
