Invalid token exception JWTTokenGenerationResource JWT_ISSUER_INVALID Issuer of the token is invalid
vshanmugavelayu
11-Garnet
Facing issue to validate Connection on ThingWorx OData connection while using SSO with Microsoft Entra
2025-02-12 07:53:10,084 INFO [ajp-nio-127.0.0.1-8011-exec-5] wt.jwt.oauth2.token.AuditLogger.Log - Start verifying JWT access token.
2025-02-12 07:53:10,084 DEBUG [ajp-nio-127.0.0.1-8011-exec-5] wt.jwt.oauth2.token.AuditLogger.Log - getVerifier() --> start
2025-02-12 07:53:10,084 DEBUG [ajp-nio-127.0.0.1-8011-exec-5] wt.jwt.oauth2.token.AuditLogger.Log - Azure AD verifyMandatoryAttributes() --> start
2025-02-12 07:53:10,084 DEBUG [ajp-nio-127.0.0.1-8011-exec-5] wt.jwt.oauth2.token.AuditLogger.Log - OAuth2 verifyMandatoryAttributes() --> start
2025-02-12 07:53:10,084 ERROR [ajp-nio-127.0.0.1-8011-exec-5] wt.jwt.oauth2.token.AuditLogger.Log - Invalid token exception: (wt.jwt.servlet.JWTTokenGenerationResource/JWT_ISSUER_INVALID) wt.util.WTException: Issuer of the token is invalid.
at wt.jwt.framework.JWTTokenVerifierDelegate.verifyIssuer(JWTTokenVerifierDelegate.java:148)
at wt.jwt.framework.JWTTokenVerifierDelegate.verifyMandatoryAttributes(JWTTokenVerifierDelegate.java:334)
at wt.jwt.oauth2.token.OAuth2JWTTokenValidationDelegate.verifyMandatoryAttributes(OAuth2JWTTokenValidationDelegate.java:84)
at wt.jwt.oauth2.token.AzureADOAuth2JWTTokenValidationDelegate.verifyMandatoryAttributes(AzureADOAuth2JWTTokenValidationDelegate.java:74)
at wt.jwt.framework.JWTTokenServiceProvider.verifyToken(JWTTokenServiceProvider.java:190)
at wt.jwt.framework.JWTTokenServiceProvider.getClaims(JWTTokenServiceProvider.java:140)
at wt.jwt.oauth2.token.JWTLocalTokenService.loadAuthentication(JWTLocalTokenService.java:94)
at org.springframework.security.oauth2.provider.authentication.OAuth2AuthenticationManager.authenticate(OAuth2AuthenticationManager.java:87)
at com.ptc.eauth.identity.oauth2.rs.ResourceAwareOAuth2AuthenticationManager.authenticate(ResourceAwareOAuth2AuthenticationManager.java:44)
at org.springframework.security.oauth2.provider.authentication.OAuth2AuthenticationProcessingFilter.doFilter(OAuth2AuthenticationProcessingFilter.java:156)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:334)
at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:105)
at org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:215)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:178)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:354)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:267)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:197)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:97)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:543)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:135)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:92)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:78)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:367)
at org.apache.coyote.ajp.AjpProcessor.service(AjpProcessor.java:526)
at org.apache.coyote.AbstractProcessorLight.process(AbstractProcessorLight.java:65)
at org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:882)
at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1657)
at org.apache.tomcat.util.net.SocketProcessorBase.run(SocketProcessorBase.java:49)
at org.apache.tomcat.util.threads.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1191)
at org.apache.tomcat.util.threads.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:659)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.base/java.lang.Thread.run(Thread.java:834)
2 REPLIES 2
Take a look - "ThingWorx Navigate configured with SSO (direct connection to Entra ID) fails to retrieve data from Windchill": https://www.ptc.com/en/support/article/CS415824
Hello @vshanmugavelayu
It looks like you have a response from a community champion. If it helped you solve your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
