We have a requirement to connect ThingWorx with Windchill using the OData Connector configured with Fixed Authentication. However, Basic Authentication is disabled on the Windchill server.
When I configure Fixed Authentication using the Windchill org admin account, I get the following results:
ValidateConnection: 200 (Success)
RefreshEndpointCache: Success
GetEndpointList: returns an empty array [] (no endpoints)
Could someone please advise how we can populate or retrieve the endpoint list for this Fixed Authentication setup on this server?
Thanks in advance,
VV
Hello @VV_14105315,
It looks like you have a response from a community champion. If it helped you solve your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
