Hi ,
i am using ESP8266 board., i followed the tutorial name "Connect an Arduino Developer Board" and used the code given in it. By using Arduino IDE i compiled and upload the code in it with necessary changes in code like WIFI SSID name, WIFI password, and in place of
const char TWPlatformBaseURL[] = "https://pp-2007011431nt.devportal.ptc.io";
the above code i have replaced it with my thing Worx server address which i am usually going to access it using url https://xxxxxxxx.thingworx.com
and app key. also i have created AND i have permitted the visibility of the resources to everyone in the thing Worx composer and i have followed each and every step given in the ptc tutorial but still my esp8266 board is not connecting to thing Worx, please help me still what changes I need to do in my code or what needs to be done in thing Worx ......
here is the code which i have compiled in my Arduino ide
* ESP8266_ThingWorx_REST_Demo.ino
* (c) PTC, Inc. 2016-2020
#include <Arduino.h>
#include <ESP8266WiFi.h>
#include <ESP8266HTTPClient.h>
#include <WiFiClientSecureBearSSL.h>
// WiFi Definitions //
const char WiFiSSID[] = "shree"; // WiFi access point SSID
const char WiFiPSK[] = "shreeexxxxx"; // WiFi password - empty string for open access points
// ThingWorx server definitions //
// modify for a specific platform instance //
const char TWPlatformBaseURL[] = "https://xxxx-dev-twx.es.Thingworx.com";
const char appKey[] = "26e717cf-b1f0-466d-8d86-403de15xxxxxx";
// Pin Definitions - board specific for Adafruit board//
const int RED_LED = 0; // Thing's onboard, red LED -
const int BLUE_LED = 2; // Thing's onboard, blue LED
const int ANALOG_PIN = A0; // The only analog pin on the Thing
const int OFF = HIGH;
const int ON = LOW;
// this will set as the Accept header for all the HTTP requests to the ThingWorx server
// valid values are: application/json, text/xml, text/csv, text/html (default)
#define ACCEPT_TYPE "text/csv"
//Attempt to make a WiFi connection. Checks if connection has been made once per second until timeout is reached
//returns TRUE if successful or FALSE if timed out
boolean connectToWiFi(int timeout){
Serial.println("Connecting to: " + String(WiFiSSID));
WiFi.begin(WiFiSSID, WiFiPSK);
// loop while WiFi is not connected waiting one second between checks
uint8_t tries = 0; // counter for how many times we have checked
while ((WiFi.status() != WL_CONNECTED) && (tries < timeout) ){ // stop checking if connection has been made OR we have timed out
tries++;
Serial.printf(".");// print . for progress bar
Serial.println(WiFi.status());
delay(2000);
Serial.println("*"); //visual indication that board is connected or timeout
if (WiFi.status() == WL_CONNECTED){ //check that WiFi is connected, print status and device IP address before returning
Serial.println("WiFi connected");
Serial.println("IP address: ");
Serial.println(WiFi.localIP());
return true;
} else { //if WiFi is not connected we must have exceeded WiFi connection timeout
return false;
//create a name for the board that is probably unique by appending last two bytes of MAC address
//return name as a String
String getUniqueDeviceName(){
String uniqueName;
uint8_t mac[WL_MAC_ADDR_LENGTH];
WiFi.macAddress(mac); // WiFi does NOT need to be connected for this call
String macID = String(mac[WL_MAC_ADDR_LENGTH - 2], HEX) +
String(mac[WL_MAC_ADDR_LENGTH - 1], HEX);
macID.toUpperCase();
uniqueName = "ESP8266Board-" + macID;
Serial.println("DeviceID>" + uniqueName);
return uniqueName;
// make HTTP GET to a specific Thing and Propertry on a ThingWorx server
// thingName - Name of Thing on server to make GET from
// property - Property of thingName to make GET from
// returns HTTP response code from server and prints full response
int httpGetPropertry(String thingName, String property){
std::unique_ptr<BearSSL::WiFiClientSecure>client(new BearSSL::WiFiClientSecure);
client->setInsecure();
HTTPClient https;
int httpCode = -1;
String response = "";
Serial.print("[httpsGetPropertry] begin...");
String fullRequestURL = String(TWPlatformBaseURL) + "/Thingworx/Things/"+ thingName +"/Properties/"+ property +"?appKey=" + String(appKey);
https.begin(*client,fullRequestURL);
https.addHeader("Accept",ACCEPT_TYPE,false,false);
Serial.println("GET URL>" + fullRequestURL +"<");
// start connection and send HTTP header
httpCode = https.GET();
// httpCode will be negative on error
if(httpCode > 0) {
response = https.getString();
Serial.printf("[httpGetPropertry] response code:%d body>",httpCode);
Serial.println(response + "<\n");
} else {
Serial.printf("[httpGetPropertry] failed, error: %s\n\n", https.errorToString(httpCode).c_str());
https.end();
return httpCode;
// makes HTTP POST to platform to CreateThing service using input string as the new Things's name.
// Returns server response code
int createThing(String nameOfThing){
HTTPClient https;
int httpCode = -1;
Serial.print("[createThing] begin...");
String fullRequestURL = String(TWPlatformBaseURL) + "/Thingworx/Resources/EntityServices/Services/CreateThing?appKey=" + String(appKey);
https.addHeader("Content-Type","application/json",false,false);
Serial.println("POST URL>" + fullRequestURL + "<");
httpCode = https.POST("{\"name\": \""+ nameOfThing +"\",\"thingTemplateName\": \"GenericThing\"}");
if(httpCode > 0) {
Serial.printf("[createThing] response code:%d body>",httpCode);
} else {
Serial.printf("[createThing] POST... failed, error: %s\n\n", https.errorToString(httpCode).c_str());
https.end();
return httpCode;
// make HTTP POST to ThingWorx server Thing service
// nameOfThing - Name of Thing to POST to
// endPoint - Services URL to invoke
// postBody - Body of POST to send to ThingWorx platform
int postToThing(String nameOfThing, String endPoint, String postBody){
HTTPClient https;
int httpCode = -1;
Serial.print("[postToThing] begin...");
String fullRequestURL = String(TWPlatformBaseURL) + "/Thingworx/Things/"+ nameOfThing +"/Services/"+ endPoint +"?appKey=" + String(appKey);
Serial.println("URL>" + fullRequestURL + "<");
Serial.println("[postToThing] POST body>" + postBody + "<");
httpCode = https.POST(postBody);
if(httpCode > 0) {
Serial.printf("[postToThing] response code:%d body>",httpCode);
} else {
Serial.printf("[postToThing] POST... failed, error: %s\n\n", https.errorToString(httpCode).c_str());
https.end();
return httpCode;
void setup() {
pinMode(RED_LED, OUTPUT);
pinMode(BLUE_LED, OUTPUT);
Serial.begin(115200);
Serial.setDebugOutput(true);
Serial.println();
Serial.println();
Serial.println();
Serial.printf("Starting...\n");
for(uint8_t t = 4; t > 0; t--) {
Serial.printf(" WAIT %d...\n", t);
Serial.flush();
delay(1000);
connectToWiFi(10);
void loop() {
String thingName = getUniqueDeviceName(); //unique name for this Thing so many work on one ThingWorx server
while (WiFi.status() == WL_CONNECTED) { //confirm WiFi is connected before looping as long as WiFi is connected
int getResponseCode = httpGetPropertry(thingName, "SomeNumber");
if (getResponseCode == 404){ // a 404 means connected, but either no Thing or no property
// first we will try to create a new Thing on the platform
int postResp = createThing(thingName); // saving the response code for retry logic in the future
// the newly crated Thing has to be enabled
postResp = postToThing(thingName,"EnableThing",""); //POST to EnableThing endpoint with no body
// after the new Thing is enabled it must be restarted
postResp = postToThing(thingName,"RestartThing",""); //POST to RestartThing endpoint with no body
// add a property to the Thing 3rd parameter is ugly because required quotes are escaped with backslashes
postResp = postToThing(thingName,"AddPropertyDefinition", "{\"name\":\"SomeNumber\",\"type\":\"NUMBER\"}");
//POST body contains JSON object with property name and property type
// after changes to a Thing's structure it must be restarted
delay(2000);
}// end WiFi connected while loop
Serial.printf("****Wifi connection dropped****\n");
WiFi.disconnect(true);
delay(10000);
connectToWiFi(10);
}t
Hi @NH_shree.
Have you checked the logs for errors? You will find the ThingWorx logs in ...\ThingworxStorage\logs.
If you're not seeing anything in the ThingWorx logs, you may have a network issue preventing the device from connecting.
Let us know if you're not able to make any progress.
--Sharon
Hi @NH_shree.
--Sharon
