The MaturityServices provides methods to handle targets and seeds. Can someone explain the difference between both targets and seeds ?
In the Windchill GUI, I can only Promotion Objects are linked.
Seeds are the items you initially select, say in Folders or Search, to create a new Promotion Request from. They are the starting data that is in the Promotion Request before any collection is applied
Target are they the items selected to be Promoted (with an appropriate state). The Promotion Request does not require one to change the state of all of the data - some can be for reference.
Hi ,
If I understand Correctly:
Target = State
Seed = Version Series
Two things you need to concentrate in Fundamentals of Windchill here:
1. Lifecycle template : Basic LC template has States, Transitions and Version
**************" attached Screenshot"******************
2. Version Series
For StateBasedSeries scenario, you may want to create "SEED"
EnumCustomize
Start the enumCustomize utility from a Windchill shell with following command
enumCustomize
Navigate to wt > series > wt.series.SeriesRangeSelectorRB
Ensure that the Keys added, match the names of the seeds example (PROTOTYPE_VER, RELEASED_VER) defined in StateBasedSeries.xml
Save and choose to rebuild the source
Rebuild Jars
Restart Server after clearing cache.
Cheers
Rahul
Hi Rahuls,
Thanks for your answer, but it is not correct. "Promotion Targets" are the objects (WTPart for example) that are handled by a Promotion notice.
Loïc
Yes Correct
Promotion Targets = WTPart/WTDocument/EPMDocument
Target State = Destination LC State
SEED = Version Scheme
I get the "same" (for me the same, I could not find any difference) objects returned from both calls:
QueryResult promotionSeeds = MaturityHelper.service.getPromotionSeeds((wt.maturity.PromotionNotice) pn);
QueryResult promotionTargets = MaturityHelper.service.getPromotionTargets((wt.maturity.PromotionNotice) pn);
Can you explain what is your requirement and what you want to achieve ?
For example "How to route workflow depending on Object type"
try
wt.fc.QueryResult qr = wt.maturity.MaturityHelper.service.getPromotionTargets((wt.maturity.PromotionNotice)primaryBusinessObject);
while(qr.hasMoreElements())
wt.fc.Persistable pers = (wt.fc.Persistable) qr.nextElement();
if (pers.getClass().getName().equalsIgnoreCase("wt.doc.WTDocument"))
//System.out.println(" ******** Wow, it is a WTDocument ******** ");
result = "route1";
else if (pers.getClass().getName().equalsIgnoreCase("wt.part.WTPart"))
//System.out.println(" ******** Hmm, it is a WTPart ******** ");
result = "route2";
else
//System.out.println(" ******** It is neither WTDocument nor WTPart ******** ");
//System.out.println(" ******** Routing to default Document path ******** ");
result = "route1";
catch (Exception e) {
Example: "How to use Business Rules to validate objects on a Promotion Notice in Windchill PDMLink"
Thanks, I get it now!
I usually select directly the objects for a promotion request, that's why I get them as seeds and targets.
Bonus question (I'm curious). Can we access the "seed" objects in the Windchill UI, or it is only an information that we get per code?
