How can I get the user that approve a promotion request using alias attributes?
wneves
I'm trying to use alias attribute to dsiplat some informations from a promotion request as attributes on a document.
I got to display the promotion request number and the promotion date using alias attributes, but I also need to display the user that aproves this promotion request.
For date and number promotion request, I use the following mapping:
roleBObject@wt.maturity.PromotionTarget~roleAObject^wt.maturity.PromotionNotice~promotionDate
roleBObject@wt.maturity.PromotionTarget~roleAObject^wt.maturity.PromotionNotice~number
But for approver, I use the following mapping but no value is displayed:
roleBObject@wt.maturity.PromotionTarget~roleAObject^wt.maturity.PromotionNotice~roleBObject^wt.workflow.engine.WfVotingEventAudit~workCompletedBy
If anyone could provide some support, I would appreciate it.
Wesley
5 REPLIES 5
Vinay_S
(To:wneves)
Hi @wneves,
I am currently working on the same process. May I know if this solved your issue since it is not working for me. Your help would be greatly appreciated.
Vinay S.
CADOpt Technologies Private Limited
Bengaluru.
rbhoraskar
(To:wneves)
  • Use following syntax in the Alias Attribute mapping on the EPMDocument:
roleBObject@wt.maturity.PromotionTarget~roleAObject^wt.maturity.PromotionNotice~primaryBusinessObject@wt.workflow.work.WorkItem~theWorkItemReference@wt.workflow.engine.WfVotingEventAudit~userRef^wt.org.WTPrincipal~name
  • Notes:
    • This will get all users related to the Review and Approve and other tasks related to the promotion request
    • The users will be displayed as comma separated value for the attribute
    • The values are mapped only if the tasks have been completed
Vinay_S
(To:rbhoraskar)
Hi @rbhoraskar,
Thank you for your time. I have solved this issue few days ago.
Vinay S.
Bengaluru.
rbhoraskar
(To:Vinay_S)
You can mark this Topic as solved then.
No one will reply after that 🙂
Cheers,
Rahul
