We using Windchill PDMLink 11.0 M030 CPS6,
and when search from the simple search item in the upper right of Windchill, it get an error like following.
Request URI: | /Windchill/wtcore/jsp/com/ptc/windchill/search/Search.jsp |
Query String: | portlet=component |
Status Code: | 500 |
Exception: | wt.util.WTRuntimeException: java.lang.ClassNotFoundException: ${domain}.Note; nested exception is: java.lang.ClassNotFoundException: ${domain}.Note |
Does anyone know the solution?
This problem solved by PTC technical support.
Follow is same problem and solution.
