Can an href open an edit window?
smccoy
Our users would like the ability to open an edit-window based on an href. Is there something that we can add to the query string that will only the editable version of a window instead of the read-only window?
Example:
We have this working to open a read-only window for an item.
<a href="integrity://localhost:7001/im/viewissue?selection=12362">
We are looking for something like the following to open an editable window:
<a href="integrity://SPA-CL-B34FYW1.corp.irco.com:7001/im/viewissue?selection=12362,edit=1">
Is this possible? And if so, what is the syntax?
-Sean
1 ACCEPTED SOLUTION
LLawton
(To:smccoy)
The command for http is simply "editissue", but it doesn't work with url: integrity.
The message I get is: MKS154477: Command "editissue" is not supported for use in Integrity URL links.
LLawton
(To:smccoy)
smccoy
(To:LLawton)
Thank you for the quick response. I'll enter a case number to get an RFC created for this. Hopefully, we're not the first to request this functionality.
-Sean
KaelLizak
(To:smccoy)
Hi Sean,
For your information, not all href functionality that works against the Integrity server with an http protocol works against the Integrity server with an integrity protocol.
There is a similar feature request for im createissue with integrity://. You might want to point that out in the ticket you open, as it is likely closely related functionality.
Kael
Kind Regards,
Kael Lizak
