How to integrate Simulink with Integrity Modeler
  • January 30, 2017
  • 3 replies
  • 9120 views
Hello !
I'm searching for a method how to integrate Simulink with Integrity Modeler. I'm working with Simulink synchronizer, but there is always a mistake:
''An error occurred whilst interfacing with Simulink.
'  0×0 empty char array' is not a valid model name because it is not a valid MATLAB function name.  ''
Can someone help me and show a simple example how to integrate Simulink with Integrity Modeler?. ( tutorials e.t.c)
John
Have you reviewed the Help topic "Integration for MATLAB Simulink"?
There's lots of information on setup and how to use the integration.
I would also check the Modeler Release Notes (Support for Third Party Products) and confirm you are using a supported version of Simulink.
If there is still a specific issue, you should log a call with PTC Support.
regards,
Patrick
There is an example Simulink model provided in the Examples repository called "Speed Controller". Recommend you use the model provided with Modeler 8.3 M020 (also called 8.3b). You will need Visual Studio and obviously Simulink installed to run. View the Readme inside the model for more information and refer to the Help.
Hopefully this will help you get started.
regards,
Patrick
In Modeler 8.4 we will supply step-by-step instructions for running a simulation with the Speed Controller example model.
regards,
Patrick
You can now use the integration with Phoneix Integration ModelCenter to integrate with Simulink.
You can find details in the Help, and also some demos on our YouTube channel:
https://www.youtube.com/watch?v=mm0bdIFyHWk
https://www.youtube.com/watch?v=FuvLIIkiRnU
regards,
Patrick
